Can a PIR motion sensor be used with EZB4. If so can you show mw an code example? Thanks
— Edited
Waveshare Bus Servos
— Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol.
You sure can use a PIR sensor with the v4. It uses a digital port (with regulator if needed). Here's a quick script example...
This is a very basic script, so you may want to add "Repeat" commands in to your script. Here is the link to a thread I started asking the same question, and a short video demo.
Thanks, Just what I needed.
