Is there a variable that shows the stations of the personality gen. ? See I want to turn the personality gen on and off or pause ON or OFF according to a variable. What I did not want to do is have the personality gen already on then turn off the pause, that may restart the personality gen. and reset the timing on it.
— Edited
I'm now using the ON / OFF for the personality gen. Seems to work fine.
I am not sure if this is what you found but I use the code:
ControlCommand( "Personality Generator", pauseOn ) ControlCommand( "Personality Generator", pauseOff )
in my code to activate or stop the personality generator without having to physically check or uncheck the box. Also there is a gear button on the personality generator panel that will allow you to pause the scripts while the robot is moving forward etc.
Aaron
