Single Camera Servo Server icon Single Camera Servo Server — TCP video server for Unity clients to stream camera video and send servo positions to ARC for remote robot control Try it →
Resolved Resolved by Geoff!
No Power
My EZ Robot isn't powering up correctly. I just took the unit out of the box for the first time, completed the barrel wiring and connected it to the battery case. The unit did nothing until I picked it up and touched the heat sinks with two fingers when it flashed briefly (both blue and red) and then went dark. The batteries are fresh and I've checked the connections on the sinks and they seem fine. I've searched the boards but can't find a diagnosis.
Can anyone help?
Thanks,
Daniel
@Mulberry, you can pull up on the plastic portion of the fuse with a pair of needle nose pliers to remove it. Or if you have a multi-meter you could check the fuse for continuity by turning the EZ-B over and measure between the 4 solder tabs. Any two tabs on the left should have continuity with any of the other two tabs on the right.
Also since you said that putting pressure (squeezing) the two heat sinks together would turn on the LEDs then look around the soldered contacts on the dc jack that is mounted to the board. It's possible that there could be a poor solder joint there as well. And while you're looking around make sure the screws that hold the two FETs against heat sinks are tight.
Thanks Robot-Doc. I checked the fuse and it looks fine but now the unit doesn't flash when I hold it by the heat sinks. This must be a connection problem somewhere in that area. I think returning the unit for repair is my wisest option. I'm afraid if I mess with it anymore I may exacerbate the problem or worse damage the board beyond repair. As it stands if I don't get this working I may damage my marriage beyond repair.....
sick
Thanks to everyone who chimed in on a solution. All were tried but I'm still unable to get stable power to the unit. EZ Robot will take a look at the unit and see what they can do. I'll keep my fingers crossed.
Daniel
