OK, some of you may have seen me on another forum asking about my charger earlier about a month ago.
Facts:
I had an 1800 mAH NiMH battery. It blew UP! Bang! and caught on Fire. Fissle, smoke. I had a 3800 mAH NiMH battery. It is still good. My charger shorted out and now gives a constant 24 volts dc.
The batteries are rated 7.2vdc.
Looking on ebay, I found a perfect 7.2 volt smart charger that is made for NiMH batteries. Did I buy it? NO. I saw another battery smart charger that had an OCTIPUS cable for the same price. I bought it.
Now, After I got it, I threw away the packing and receipt and boxes. I NEVER return things. The shipping looses most of the money in the return process. I just usually eat it.
Next, I wimpered a little when I read that it was made for LiPo type batteries.
I called ALL-Battery in CA. They told me "NOOOOO! you cannot use this charger on a NiMH battery, it is made for a Lipo type battery!
It had a very pretty gold box with dancing LEDS, etc. Very pleasing to the eye.
I cannot afford to purchase this new charger for another two months. What do YOU think about the Whole shootin' works? What would you do besides sending everything back and loosing which I am not going to do. I could buy a Lipo battery, but I already have the Tenergy 3800 and it has served me well.
Thanks in Advance.
Mel
If your looking to try LiPos go right ahead however you best either get an alarm or auto cutoff if you are to use them, for discharge if cell is discharged to low you'll never be able to recharge it. Also there a plenty of warnings to go about charging and certain handling situation.
orwnic82,
I already have two good NiMH batteries. I wish to charge them with a LiPo smart charger.
OK, it seems to be a fact, you cannot charge LiPo batteries in a NiMH charger. They will blow up probably.
But, what about the OTHER way around. Charging a NiMH battery in a LiPo charger. I haven't got an answer yet.
problem solved. I just bit the bullet and ordered the correct NiMH battery charger. I was suprised that no one knew the answers.
