Hi,
I just received my UART-WIFI module from China which is fully compatible with ELECHouse module.
Stackable Uart WiFi Module Kit
Manual and Software are online same as ELechouse Module.
I had two problems while working on it and appreciate your support:
- The pin connectivity is not compatable with the existing BT module. this may require cable connection or smal PC adaptor.
- I have Apple TC with Apple Extreme around the house that create the Encrypted WPA2 WIFI network. The UART-WIFI module does recognize the network but does not connect to it and keep geting connection failure SSID and Password verified.
- I tested connectivity by creating new open WLAN using an old Linksys Router. It did recognize and connected to the new WLAN using the manual process in the UART-WIFI configuratore tool.
- I could not automate the process to ensure if I connect the Module to the EZ-B will do automatic connections and link for normal operation.
Thanks in advance.
Update: I managed to access the WPA2 Network still need to test the physical connectivity to EZ-B and the communication link with ARC.
