Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
Resolved Resolved by ptp!
Mqtt Conecting
i am trying to use the MQTT plugin with no luck. I have a host on 192.168.2.8 and so far am just hitting the connect button but its timing out with 'uPLibrary.Networking.M2Mqtt.Exceptions.MqttCommunicationException' was thrown. Then high cpu use and a task kill to get back full operation? This is on a Tiny, if I can get this working I plan on getting a /4 also and a SSC32 to help split the power. I am 3/4 thru an Inmoov build and want/need MQTT for openhab connection.
Thanks all
Success thanks ptp, it was the old version 0.15. Its the one you get from apt you have to add https://repo.mosquitto.org/debian/mosquitto-wheezy.list to get newer versions. Now I get a quick connect in EZ. The Openhab Pi has been up for so long I kind of forget it. I will start a new thread on the SSC-32 questions.
Thanks
