Servo Recorder icon Servo Recorder — Record and replay named servo movements with adjustable speed/direction (-5 to +5), multiple recordings, ControlCommand triggers and status var Try it →
Moving Head Sound Detector
How do I get my sound detectors to give constant voltage readings on the ADC Graph?  I am using the two detectors to see where the loudest signal came from then move the robot's head toward the loudest.
I have read all I can find on Synthiam including the Community and Tutorials but can not see anything that will solve my problem.
The problem is I can't get a consistent signal from in the ADC Graph.  The line graph will jump up and down even with the a constant audio signal coming from my sound generator.  Since their is no sound consistency I can't write script to make the head move.
Is my problem having to do with the wrong sound detectors or the way the information is handled by the Ez-Robot program?
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
ADC Graph by Synthiam
Historical ADC graph and numeric readout (0-255) for 0-3.3/5V inputs; configurable board/port, sample interval, color, and pause for ezb controllers.
ADC Value by Synthiam
Display ADC port voltage and 0-255 linear values (0-3.3/5V); configurable board/port, units, multiplier and sample interval.
ADC Meter by Synthiam
ADC VU meter displaying 0-3.3/5V as a 0-255 linear meter; configurable board/port, sampling interval and color; pausable real-time readings.
#17
Hi. Richard gave me the script that would help me make the sound sensor work.
Here is the script:
:loop $left=GetADC(adc0) $middle=GetADC(adc1) $right=GetADC(adc2)
if ($left>$middle)
if ($left>$right) servo(D0,1) // left is highest sleep(2000) goto(loop) endif
endif
if ($middle>$right) servo(D0,90) // middle is highest ELSE servo(D0,180 // right is the highest endif
I would like to understand this script.  Where can I go to understand the format of the loop script.  I have been looking on Synthiam to understand loop but to no avail.  I know it loops scripts but I do not understand all the loops and their inset protocol .  I really want to write my own scrips using the loop script but right now I do not understand it and don't know how to find how to use it.  Please Help.
#18
Thanks for ideas and help.
I am still trying to use Richards script to make my robot Max turn his head toward who is talking.  Richards script helped me a lot.  I still cannot get it to work but I am working on it.
https://www.youtube.com/watch?v=r8qBdeMNlJA&feature=youtu.be
Above is a my YouTube video that will show you that the three sensors are not peak coordinated therefor I cannot compare voltages at the instance sound is made.  I also added a steady tone of 1141 Hz, from my Tone Generator which should show a steady tone on the three Read ADC gauges. If I could get a steady tone on my gauges,  I could balance the gauges using the sensitivity on each sound detector.  Sensors are Sound Detectors by RobotDyn.  I could then use the steady tone from my Tone Generator to balance them.
Here is a pictures of my setup.
Thanks for all the help.  Please give me some direction to go.
Ellis
