Servo Summary icon Servo Summary — All-in-one servo view showing and editing servo positions and speeds; add servos and resize the control to fit. Try it →
Motor And Potentiometer Script Help
I had this script working in ARC with only one board. I added a second board and added a 1. to the beginning of each command in the scripts but now I cant get the ports to turn of or on.
I also get Syntax errors after I've run the scrip a few times and (I dont think) I made any changes.
I also added the .1 in the call scripts "move right" and "move left". Please see each below and let me know what I'm doing wrong:
#Main script:
This script will move an HBridge to
the specified ADC value.
1.if ($adcSpecified = 0) goto(Error)
:Start
1.$adcCurrent = GetADC(adc0)
1.if ($adcCurrent $adcSpecified) goto(RotateRight)
1.if ($adcCurrent = $adcSpecified) goto(RotateStop)
goto(Start)
:RotateLeft 1.Set(d1, on) 1.Set(d0, off) Return()
:RotateRight 1.Set(d1, off) 1.Set(d0, on) Return()
:RotateStop 1.Set(d1, off) 1.Set(d0, off) Halt()
:Error Say("There is no specified position to move too")
#Move Right Script:
This script will move the motor into the
right position
1.$adcSpecified = 150 ControlCommand("Hips", scriptStart)
#Move Left Script:
left position
1.$adcSpecified = 50 ControlCommand("Hips", scriptStart)
Any help is welcomed. Thanks, Dave Schulpius
Do I have to have both boards powered up and connected to make my new script work on the second board (first board shown as 0 and the second shown as 1 in the connect panel)? I only have the soecond board powered up.
OK, I have at least one D ports now working with the script. I added a "Set" control for the two ports I'm useing on the second board and confirmed that they are turning on and off with a volt meter. I've also found how to get by the Sytanx Error I go the call scripts and save each. That way I can go into the main script and make changes and save.
I've played with the script and have it turning on at least one of the Digital ports when I start the call scripts. However when I turn the pot the Varible Watch panel showing the "$adccurrent" does not change. It's stays on 1.0. I think this means it's not reading the ADC port of the second board. I still have sonething wrong with the main script. Here's the script as it is now (any help is welcomed):
:Start
$adcCurrent = 1.GetADC(adc0)
goto(Start)
