Sound Script icon Sound Script — Replaced by Sound Script (Speech Script) robot skill; see Synthiam's Speech Script support page. Try it →
yes indid.you all work so hard and with great sucses.you gave many, there dream robot&hobby.
Thanks @Nomad6R! :D
Has anyone built the JD robot much taller using the extension modules and would it still walk if it is much taller?
roborad
jd has hips that works perfect.i think if you want a bigger robot, you will need to use metal brackets.
Yes thanks Nomad,That is what I thought too but It would be a worth while project if the servos are strong enough.
you can always try,you never know what you come up with. i think the cube on elbows and knees,would be possible. then you just need to adjust some motions like sit down&stand up.
