Servo Script icon Servo Script — Bind scripts to servo moves (V1-V99); triggers on position/speed/accel changes and provides ports, positions and speeds arrays for custom control. Try it →
Meccanoid 4ft Tall Robot
Meccanoid 4Ft Tall Robot
so i was wondering if any one has seen and consider the use of turning the meccanoid 2.0xl 4ft robot from its factory controlled unit to ez-v4 version. it is a very simple build and would be great as a quick humanoid build but i wasnt for sure if the 4-speed smart servo's that it comes with would be compatible with the ez-v4 brain? i mean even if not the the body structural build is still worth using with the servo's used by ez-robot. so any of you guys ever considered the build? here is an example of the robot below
