Intel Realsense D435i icon Intel Realsense D435i — Connect Intel RealSense depth cameras to ARC NMS for depth-based distance detection, point-cloud mapping, video streaming, and navigation telemetry. Try it →
MMA7455L Accelerometer
*Note: this is temporary until the next SDK is released. Then this page will change because there will be an embedded class in the EZ-SDK and ARC.
Address
    byte ITGWriteAddress = 0x1D << 1;
    byte ITGReadAddress = (0x1D << 1) + 1;
i2cRead - Create a generic function to read from the device (1 byte at a time)
    byte i2cRead(byte registerAddress) {
      ezB_Connect1.EZB.I2C.Start();
      ezB_Connect1.EZB.I2C.Write(new byte[] { ITGWriteAddress, registerAddress });
      ezB_Connect1.EZB.I2C.Restart();
      ezB_Connect1.EZB.I2C.Write(new byte[] { ITGReadAddress });
      byte val = ezB_Connect1.EZB.I2C.Read(false);
      ezB_Connect1.EZB.I2C.Stop();
      return val;
Who Am I - Assuming you have a multiline textBox1 on your form, this will write the contents of who am i register to it
      textBox1.AppendText("Who Am I: ");
      textBox1.AppendText(i2cRead(0x0f).ToString());
      textBox1.AppendText(Environment.NewLine);
Set Mode - Look at the datasheet. The mode is being set to 0101. This needs to be done before any readings will work.
      i2cWrite(new byte[] { 0x16, Functions.ToByteFromBinary(0, 0, 0, 0, 0, 1, 0, 1) });
Get Mode - Assuming you have a multiline textBox1 on your form, this will write the contents of the mode register.
      textBox1.AppendText("Get Mode: ");
      textBox1.AppendText(Functions.ByteToBinaryString(i2cRead(0x16)));
Get Angles (8 bit) - This will read the current angle of the PCB in X, Y and Z
      byte x = i2cRead(0x06);
      byte y = i2cRead(0x07);
      byte z = i2cRead(0x08);
