Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
https://synthiam.com/Tutorials/Hardware.aspx?id=13 is a good place to start.
Serial lcd's are much easier than i2c. Avoid i2c if you don't know much about it.:)
Connect power to the LCD. And also connect a digital wire from the EZ-B. it's easiest to use a peripheral cable.
Then in EZ-Script, you can use the SendSerial command. The syntax and help are displayed in the script editor manual:)
