Benchmark icon Benchmark — Diagnose EZ-B connection speed and reliability; benchmark ADC read rates (4-70/sec), reveal flood-control effects and optimize data throttle. Try it →
https://synthiam.com/Tutorials/Hardware.aspx?id=13 is a good place to start.
Serial lcd's are much easier than i2c. Avoid i2c if you don't know much about it.:)
Connect power to the LCD. And also connect a digital wire from the EZ-B. it's easiest to use a peripheral cable.
Then in EZ-Script, you can use the SendSerial command. The syntax and help are displayed in the script editor manual:)
