Cognitive Sentiment icon Cognitive Sentiment — Detects positive sentiment percentage of input text using cognitive ML; returns $SentimentPercentage, shows face, graph, and status for analysis. Try it →
Netherlands
#17
@ jstarne1
Hi, do you also experience flickering when changing the intensity of leds that are directly hooked up on the i/o ports?
#18
If you are noticing flinkering while using PWM - you can probably fix that with a cemaric capacitor. It because there is practically no resistance in an LED, you could be visually seeing noise
Netherlands
#19
cool! Thanks, ill give that a try. You guys are up late and must be drinking lots of coffee, I hope work is going well.
