Kann man konfigurierte Skills von einem File in ein anderes File übernehmen / kopieren? ... oder muss man die Skills immer wieder neu konfigurieren?
bitte ins englische übersetzen.
Drone Collision
— Add HC-SR04 ultrasonic sensors with an EZ-B to AR Parrot Drone v1/v2 for collision detection and avoidance
Yes, you can copy configured skills from one file to another. You don't need to configure the skills again and again. You can save your project with the configured skills and then load it into another project.
Here's how to do it:
Please note that this will merge the two projects together, so make sure you want all the skills and configurations from the saved project in your new project.
For more information, you can refer to the ARC software documentation in the support section on the Synthiam website.
What Athena means to say is merge: https://synthiam.com/Support/ARC-Overview/loading-saving-robot-projects/Merge%20Project
Wie kann ich den Skill "RGB-Animation" inklusive allen Aktionen von einem bestehenden Programm in ein neues Programm kopieren?
Erledigt!
The link that dj had provided explains the merge option. This page: https://synthiam.com/Support/ARC-Overview/loading-saving-robot-projects/Merge%20Project
Vielen Dank. Es funktioniert.
