Getrss icon Getrss — Fetch RSS via GetRSS command; populates $RSSSuccess, $RSSErrorMsg and arrays $RSSTitles, $RSSDescriptions, $RSSLinks, $RSSDates for scripts. Try it →
Jd Pc Computer Speed
I bought JD and assembled him. He's a fantastic humanoid! Now I need to buy a PC computer. When matching the specs quoted below, the computer speed is 1.7gHz (with 2.7 Turbo boost). Is this too slow?
Quote:
System Performance ARC was designed to be very efficient and run on lower scale PC's. This does not mean that we recommend low scale PC's, even though the software will run. The recommended CPU is an Intel i5 equivalent with 4GB of RAM and Windows 8.1. The 3D designer and 3D instruction interface will use video hardware acceleration, if available. Screen Resolution The minimum screen resolution for ARC is 1024x768. Ideally, the best resolution for ARC is 1920x1080.
synthiam.com/Support?id=207
The computer you have is more than enough. No need for a new pc. Just make sure you have the required operating system, which was not mentioned in your email.
DJ Sures: Thank you for the fast reply. I have only Apple Macs now and need to buy the PC. Here's a list of the complete PC specs under consideration.
Acer, 1.7GHz Intel Core i5 4210U Dual-Core Intel Turbo Boost Technology 2.7 GHz 8GB DDR3L SDRAM Cache Memory 3 MB 1TB Hard Drive 5400 rpm Display 15.6in 1920 x 1080 Display, IPS, LED-backlit, TFT, Touch screen, wide screen Intel HD Graphics 4400 Video memory: Shared system memory with Intel HD Graphics 4400 IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Gigabit Ethernet, Bluetooth 4.0 Windows 8.1 64-Bit, Keyboard, Webcam (1) SD reader (2) USB 2.0 (1) HDMI (HDCP) (1) USB 3.0 (with power-off USB charging) (1) VGA (1) RJ-45 LAN (1) 3.5mm audio (in/out combo) (1) DC power in
That computer will be great for ARC
@DJ Sures: Thanks sincerely. Knowing which computers work with JD is extremely helpful. The order should go through on Wednesday. In the meantime, I'll hang out in the LEARN section - absolutely fantastic and amazing stuff! The person responsible for all this is a gifted robotics genius! I'm sure I speak on behalf of all the community when saying a big thank you of appreciation!
Thank you for the kind words:)
