Inverted Pendulum icon Inverted Pendulum — Balancing controller for Sainsmart v3 (and compatible) robots: PID tuning, real‑time telemetry, angle offset, movement and calibration via ARC. Try it →
Hi folks, I have another I2C query.
I've learned now that I2C devices have addresses meaning multiple devices can be attached. This is awesome of course.
My question is now, if I had, say 2 accelerometer's of the same type attached, can these be accessed separately? Am I correct in thinking that they would have the same address code?
For scripting I am more focused on using C# rather than ARC.
Any thoughts on this subject?
Depending on the device you may be able to change the address, it should give the command to change the address in the datasheet for it.
Never even thought of looking for a command like that. Awsome if I can
Obviously only have one of them connected when you change it's address:)
I know the BlinkM and the LCD screen I have both support changing the address.
oh of course. I'd have spent ages with them both connected and wondering why they were both changing.
I'm getting a couple of i2c cameras you see so will need to be able to choose different camera at different times.
Check the forums, I'm pretty sure (as said in the other topic I replied to just now) that the EZ-B isn't able to transmit video.
