Ez Line Chart icon Ez Line Chart — 4-series historical line chart to log and compare robot sensor values over time with customizable titles, colors, time axis and EZ-Script control Try it →
Hey guys, up for discussion is
Hey Guys, Up For Discussion Is
Hey guys, up for discussion is the speech API from Microsoft/Azure/Bing. I want to utilize a pay version of this service for CES display. I don't want the service to stop after a limit of speech-to-text is reached making Alan inoperable to voice commands.
There are two EZ plug ins. First which plug do I use with my own API key? And secondly can anyone explain to me the cost breakdown from Microsoft for this service?
#41
Ugh...  I hate everything about Vegas.  I am going to a conference in February at Ceasars Palice and I plan on arriving an hour before the opening reception, and leaving before  lunch on the last day to spend as little time as possible there.
#42   — Edited
Yeah you can’t believe the amount fees and costs for everything. If you exhibited a lot investing in a portable power system and direct link to a satellite might be in order;)
#43
...here is a cut and paste and screen grab of the error...
#44   — Edited
That’s an error from the service. Other than disabling the pause command in the configuration, I don’t have any suggestions. Did you try googling the error code from the message?
#45
Thanks DJ. No worries. I’ve only a few more weeks before CES, so going to move on to other options as times running out.
#46
The plugin no longer works for me since the update no matter what region I try. It says WebSocket upgrade failed with an authentication error (401).
#47
You may have to update the key in azure. Because Microsoft has legacy and ultra legacy and recent key versions - it’s kind of a mess and difficult for us to keep track. This plugin uses the latest key type AND it will tell you in azure what region to use. You MUST use the region they specify. You cannot simply use any random region. They assign the region for you.
