Ok, so I set up my new router and all is ok except no internet connection... I can log on to the networks with any of my wifi devices/computers, but there is no internet connection... Since I am a bit daft with the network stuff I need help. This is what I did
- Logged on to my old router/modem combo and disabled the wifi...
- I am using a wired Lan connection right now in order to type this and do the above
- Set up my Dlink according to the instructions step by step
- As far as I know all cables are correct... LAN1 Ethernet port out of the modem into the internet port on back of the Dlink router
- Set up network as per instructions... passwords, network name etc...
- Result after a couple of reboots of the system... all wireless connections state "limited connectivity only"...
- The router does indicate a solid internet connection, however....
So I have no problem connecting to the network, just no internet connection with any device
- What am I doing wrong? Does the modem need different settings to allow a new router?
- Some settings in the new router I need to change or enable?
I can sure use help from some of you network guys before I pack it all up and send it back...
***I didn't set this thread for "require assistance" because I felt the credits should be EZ Robot related questions and I didn't want to abuse the credit system...
Thanks a million guys Richard
OK, so both my EZBs now have their own reserved IP address...
