Hello Community,
I would like to deploy something similar to this project NeoPixel Ring with Arduino as control board but I need to use LED strips. 60 LED qty.
Will this work for LED strips? Or is there a simpler way to control many LEDs with the EX-B
Help is greatly appreciated.
Thanks,
Mark
Hello Mark,
You can use strips instead but you'll have to change the amount of LEDs specified in the code (I believe you just have to simply change a variable). You'll also have to match the code with the LEDs you are using as there are now quite a few different types of "addressable" LEDs.
