Stream All The Video Sources icon Stream All The Video Sources — Stream video from any URI/protocol (RTMP, RTSP, HTTP, UDP, etc.) to a selected ARC camera device for real-time network feed playback. Try it →
Hello Mark,
You can use strips instead but you'll have to change the amount of LEDs specified in the code (I believe you just have to simply change a variable). You'll also have to match the code with the LEDs you are using as there are now quite a few different types of "addressable" LEDs.
