ROS2 Connector icon ROS2 Connector — Bridge ARC to ROS2 via rosbridge: publish/subscribe topics for cameras, servos, ports, NMS, variables, scripts, and movement. Try it →
France
Good Evening, I Don't Know I
Good evening, I don't know if it's possible,
I use a SARAH framework with plugins with a Dictionnary plugin that parse my answer. It works perfectly and I get my answer. I created a script that I named dico that I would like to launch with an HTTP request and a ControlCommand.
$VoiceStart = "<prosody pitch='+10%' rate='-5%' range='+5%' contour='(0%,+30Hz) (10%,-2st) (40%,+10Hz)'> "
$VoiceEnd = "</prosody>"
$search = "voiture"
$SynbotTextResponse = HTTPget("https://127.0.0.1:8080/SARAH/dictionary?text="+$search)
SayWait($VoiceStart +$SynbotTextResponse+ $VoiceEnd)
But here is my question:
You will understand, instead of voiture I would like to put the object of my research $search = "voiture"
https://192.168.1.78/exec?password=admin&script=ControlCommand("dico".........search("mysearch";)
Is it possible?
Another thing and it's important, I always have a problem with the accents in my answers. Is an update planned?
see here
Thanks
I found and it was easy as pie. I forgot to mention I use Synbot.
<Model>
<Pattern>
<Item>DICO *</Item>
</Pattern>
<Response>
<x:EZcmd>HTTPget("https://127.0.0.1:8080/SARAH/dictionary?text=<Match />")</x:EZcmd>
</Response>
</Model>
Now I will be able to parse all my sites that I wish (dico, wikipedia, weather ...) with my framework.
But I have always problem with the accents, it's impossible to use this (for the time being?).
#2   — Edited
I had already discussed the problem here
Here I have my accents in my answer.
mecanisme automatique capable d'executer certaines tâches selon un programme fixe ou modifiable
But in synbot the accents are not present and the answer is unusable.
mcanisme automatique capable d'excuter certaines tches selon un programme fixe ou modifiable
@DJ [/b]I specify that the site dictionary.reverso.net is in UTF-8,  my plugin gives the answer in UTF-8 with all the accents.
request({ 'uri' : url ,'htm':{'Accept-Charset': 'UTF-8'}, }, function (err, response, body){
 I did the tests on 2 PCs and others ARC skill plugins (pandorabot, synbot,...)
@Dj Well, I found a solution by doing a regex. It's not really beautiful but it works, that's all that matters.
match = match.replace(/[eèê]/g,"e");
