I ordered a Solidoodle 2 Pro which arrived today. I also ordered with that 2 rolls of filament. It should be 4 total pounds of material to start with.
jstarne1
— Edited
Joystick (Xinput)
— XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts.
Ok so i spent a few hours going through recommended steps tuning the machine and I'm sure a few more are needed. The very first items I had to print were adjustment knobs for the bottom of the bed. This allows a immediate adjustment soon as a print starts to ensure even build. Also the Kapton tape that was included only lasted through these 3 knob prints. I switched to painters tape.
I must say the knobs are a great idea however the order of startup steps is stupid. The recommended adjusting the zip axis first , then print knobs , then level the print bed where you will need to redo the zip axis adjustment. It makes must more sense to level the bed first with the machine off and the do the Z axis adjustments when the machine is on.
Next my first print was the ear pods on the ironman helmet.
I will say that painters tape is a clear way to go to make sure the print doesn't peel and also to protect your print bed from scratches when you pry your part off.
that's awesome.
Wow! congrats Josh! Looks like your first print are going well......Cant wait to see all the items you'll be printing...Its def encouraging for the wanna be buyers!
With your painting skills, changing colors should be easy
Too cool Josh. Nice work. Thanks for posting this stuff. Having aspirations of being a 3d printer owner one day, it's interesting to watch someone else's into journey.
Josh, I was going to tell you to expect a learning curve, it took me about 2-3 weeks to get really comfortable with the machine. But it looks like you have got it. You will have SO much fun with it. I have a FlashForge Create which is the same as a Maker-bot Replicator One. Except I have all the Upgrades and I can print in either PLA or ABS. I have had more fun with this machine except when I draw my own models. This is where it takes skills like Aameralis has. Also, good luck on your new business. Oh, and ALL print beds are not level. That is why you put a piece of glass, lexicon, or other material on top of it.
@ Mel - so do you have problems with filament absorbing water through the air? I've heard rumors it causes print issues but then I see other people with rolls of filament out in the open.
Also about the print bed I was able to get it flat by adjusting the tension on the build plate and the plate started to flatten out.
