Hi,
I'm looking at using something like this for EZ-B
https://www.robotshop.com/4wd1-robot-aluminum-kit-3.html
Will EZ-B power it?
Is there another suggestion?
jc
Get Line Containing From Array
— Adds GetLineContainingFromArray() ez-script function to return the first array item that contains specified text, simplifying substring searches.
Hi,
Will EZ-B power it?
jc
Suspect you would need h-bridges for the motors. They don't specify the mperage, so more research needed. Seems awefully expensive for a bot with only 5lbs carrying capacity.
I noticed on the assembly guide that they are using a Sabre-tooth motor controller.
Another good base is Traxxas chassis, good quality, good suspension, etc. and you can find them used on local buy and sells.
