PWM Slider icon PWM Slider — Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection. Try it →
Great job - however, disable the Glyph option. There is no need for the Glyph option because you are only tracking the specific color using Multi Color.
Also, there is no need to add the code in the Glyph section as well. There is no glyph being used in your camera.
For information on what a glyph is, press the ? button next to the X on the Camera Control. EVery control has a ? next to the X. When you load ARC, there is a message that tells you about the ? button next to the X. Use the ? button next to the X to find more about controls. The ? button is on every control next to the X close
indeed it works also whithout the glyph.
