The Navigator icon The Navigator — Path-planning navigator using ARC NMS position and obstacle data to map, log trajectories, and autonomously follow waypoints. Try it →
Failed To Load Bootloader
Hello,
E-Z B firmware update fails with "Failed to load bootloader!". As far as I know, I have the standard Windows bluetooth stack.
Ideas?
Thanks, Crile
Please follow the tutorials from the tutorial section here: https://synthiam.com/Tutorials
You can tell if you have the Microsoft bootloader by comparing your screen against the video. You can include a copy of the firmware log message in your post also. We won't be able to help you without information:)
It finally worked. Had to remove other bluetooth devices. Thanks.
