Websocket Client icon Websocket Client — WebSocket client for ARC: open/send messages, store server responses in a variable, run a response script, and track connection status. Try it →
Ez-B V4 Camera Not Working
I am happy to say I received my EZ-B v4 and Camera Combo and the EZ-B v4 Developer Kit. I was testing it all out and one of the cameras is not working. It flashes the blue led a few times and I get the dreaded Camera disabled. The other camera works like a charm. I tried both EZ-B v4s making sure I had the IP address correct and have the same result on both EZ-B v4s ( one camera not working). I really think the camera is faulty as I have poured through all the threads and tried every remedy step by step.
Any thoughts?
Take the case off of the camera and try to re-seat the boards on the camera. Also re-seat the camera cable. If those two things don't do it for you, I would have to agree that it might be a dead camera.
If re-seating the camera board doesn't work - Contact Us and add a link to this thread so Customer Support can see the description:) Sounds like you need a new camera!
Ok I gave it a good go. I re-seated it and even swapped wires and still it does not work. Thanks for your help guys.
WoW I contacted customer support and I received the camera today. That was fast and it works great.:)
United Arab Emr
Hello this is my new JD when i try to open the camera my camera show this type of message i did not understand what is this and what i am doing anybody can suggest me what i am doing
ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object ) ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.TKCnV5dEK6(Byte[] ) at EZ_B.EZBv4Video.BEr2DfF4cs(Int32 , Object )
Hello @alyousuf,
Another community member had an error similar to yours here
Are you connecting to JD via AP mode or Client mode?
Please see the learn section for more information on connection modes and more!
United Arab Emr
I am connected on client Mode
You will need to change the Camera IP address to 192.168.1.1:24
Port 24 is needed.
