Hello all,
Can you turn off the EZ-B's battery safety feature off?
Any help is appreciated
Joshua.
Set Digital
— Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only.
Hello all,
Joshua.
Yes, look in settings of the connection control... There you can disable low battery warnings and cutoff voltage... Not recommended if you are using lipo batteries however...
Ok thank you
Hey right on! I was wondering about that too as I can use my new Nihm battery instead of the Lipo and let the voltage get really low, will last longer before shutting down the EZB! The more powerful Lipo I have can then be used just to power the H bridge and motors!
