Sketch Pad icon Sketch Pad — Script-driven Sketch Pad for ARC: draw shapes, text, lines and faces via controlCommand() to visualize object locations, paths and robot data. Try it →
Ez-B Not Working
hi community ! i have some problem with m ez-b it had stoped working by mistate i had kept it on a conductive surface and i think the crystal has blown off so i replaced it ...... but it is still not working ,the blue led is not working. i wan througd your diagnoses video.....ic is working. plese help me ....... i also have arduino boards like uno..can i use instead of it ..... also i live in india .and i cannot send u ez-b for repare.......
I had a similar issue. DJ will know best, but I found that I had to reflash the ROM. Have you attempted to connect with the ROM update application?
Wow, you and robotmaker write exactly alike and seem to like to talk about arduino for no obvious reason. Are you both from India? It's odd your tag says your from the USA. Why cant you send the board to the USA? Shipping charges are not that much. If time is an issue then why have you held this damaged board for four months? Good luck with your issue.
