Microphone icon Microphone — Record audio from your PC mic, auto-trigger and edit sample rate/effects, then play or export recordings to an EZ-B v4 SoundBoard for robot playback. Try it →
More than likely it'll work. Im on my phone right now but when i get to a desktop i will look at the datasheet.
Yes it will work on the V3 and V4 since it is I2C. You will need to know the I2C commands required to read from it through. Check the datasheets and also read up on I2C if you plan to use one, I2C can be confusing.
@Rich Thank you for the fast information.
