PCA9685 Servo Driver icon PCA9685 Servo Driver — Drive 16 servos over EZB I2C with a PCA9685 PWM controller, using ARC servo commands and hardware-timed outputs. Try it →
Sweden
Error When Starting Applications
Hi, When starting EZ-B builder or firmware upgrade application I receive the following error:
There was an error loading EZ-B DLL: System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseSingle(String value, NumberStyles options, NumberFormatInfo numfmt)
at System.Single.Parse(String s, NumberStyles style, NumberFormatInfo info)
at FaceDetect.Net.Haar.HaarClassCascade.ParseInput(XDocument xDoc)
at EZ_B.Camera..ctor(EZB ezb)
at EZ_B.EZB.init()
OK
.Net framework 4.0 on Windows 7 x64
/Eugene
Hello Eugene,
This issue has been reported by one other person. I still have not determined the cause of it. What is your default language/localle and currency, etc set for? You can find that under Region and Language in Control Panel.
Norway
Yeah, just change the system language to english. :)
Even with the new version I posted last night?
