Floor Map icon Floor Map — Draws a live floor map of robot movement using Movement Panel, logging direction, distance and heading; configurable speed and turn settings. Try it →
Environment Requirements
I would like to know specifically if your robot can be programmed using Ipad, if so what is the required software or what is that I need to install. Thank you, Julian Robledo
Hello Julian,
Yes! You can download ARC mobile and program the robots with Blockly or Roboscratch.
Please check out our learn section, which has some tutorials to guide you with using RoboScratch and Blockly using the mobile app. Just select which robot configuration you are interested in and then which coding interface you'd like to use on the lefthand side.
Here's an example under the Hexapod, Six, learn section:
https://synthiam.com/Community/Tutorials/75?courseId=2
