Programming With Pictures icon Programming With Pictures — Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots. Try it →
Custom Movement Panel V2 H-Bridge Support
I have a question about the ARC robot skill "Custom Movement Panel v2."
My robot is a two-wheel differential drive. The H-bridge I’m using requires a forward/reverse (direction) input pin and a PWM pin for each motor. Is there a convenient way to connect the "Custom Movement Panel v2" (or a similar Robot Skill) so it can control one direction pin and one PWM pin per motor?
Also, my H-bridge needs the PWM duty cycle to be limited to 95% or less to drive correctly - is that something the skill can accommodate?
For clarity: I haven’t specified how the H-bridge is connected yet. I’m planning to connect it via an EZB (so the H-bridge inputs would be wired to EZB digital and PWM outputs), but if other connection models are relevant (direct USB/serial driver or PC-connected hardware), I can provide details.
USB
Digital 21
