Sharp IR Radar icon Sharp IR Radar — Radar-style Sharp IR scanner for EZB ADC: sweeps sensor, displays distance dots, logs ADC voltage, and can steer/avoid obstacles via Movement Panel Try it →
New Zealand
Confirming A Human Response
This is one of my most used scripts. It is often called after my robot asks a question that requires a verbal response.
Positive responses = Yes, Affirmative, True, Okay, Correct Negative responses = No, Negative, Incorrect, False, Wrong Undecided responses = Maybe, perhaps, possibly
It converts the various answers to either Yes, No, Undecided or No Response and stores it in $Response for use by the main routine.
  • Enjoy Tameion (Wayne)
Confirmation of a spoken response |
Initialise Variables
$Name_Response_Loops=0
Start the sequence
:Confirmation $Name_Response_Loops=$Name_Response_Loops+1 Print ("Check # $Name_Response_Loops" ) $Response = WaitForSpeech(10, "Yes", "Affirmative", "True", "Okay", "Correct", "In correct", "No", "Negative", "False", "Wrong", "Maybe", "Perhaps" )
Report initial response including any timeout
IF ($Response = "timeout" ) Print ("No response from User!" ) Else Print ("I Heard you say $Response" ) ENDIF
Take necessary action according to response
IF ($Response = "Yes" ) goto(Positive) ELSEIF ($Response = "No" ) goto(Negative) ELSEIF ($Response = "Affirmative" ) goto(Positive) ELSEIF ($Response = "True" ) goto(Positive) ELSEIF ($Response = "Okay" ) goto(Positive) ELSEIF ($Response = "Correct" ) goto(Positive) ELSEIF ($Response = "In correct" ) goto(Negative) ELSEIF ($Response = "Negative" ) goto(Negative) ELSEIF ($Response = "False" ) goto(Negative) ELSEIF ($Response = "Wrong" ) goto(Negative) ELSEIF ($Response = "Maybe" ) goto(Undecided) ELSEIF ($Response = "Perhaps" ) goto(Undecided) ELSEIF ($Response = "Possibly" ) goto(Undecided) ELSE IF ($Name_Response_Loops=3) goto (No_Response) ENDIF goto(Confirmation) ENDIF Halt()
All 'Yes' answers come here
:Positive $Response = "Yes" Halt()
All 'No' answers come here
:Negative $Response = "No" Halt()
All 'Maybe' answers come here
:Undecided $Response = "Undecided" Halt()
No Answer comes here
:No_Response $Response = "No Response" Halt()
You could probably simplify it with a few ORs in the IFs
i.e.
goto(Positive)
goto(Negative)
goto(Positive)
goto(Positive)
goto(Positive)
goto(Positive)
could all be replaced with
IF ($Response = "Yes" or $Response = "Affirmative" or $Response = "True" or $Response = "Okay" or $Response = "Correct")
GOTO(Positive)
ELSEIF
Then the same for negative.
There may be a way to check against a payload XML, I don't know if DJ has that implemented yet. VoxCommando (software I use for voice commanding my PC) uses XML lists for tv show names, actor, artists, albums, songs etc. etc.
So I'm thinking that the IF statement could cross reference to the XML file for acceptable responses rather than list them all out as ORs or ELSEIFs.
New Zealand
Interesting....
I tend to work vertically rather than horizontally as what is out of sight is often out of mind...lol.... will have a go tomorrow... 1am here... lol
I too work that way but have recently been playing with the OR and AND commands, more to clean up code than anything else.
I personally see nothing wrong with large nests of IF statements (I also find them easier to follow than IFs with ORs)
