EZ Gauge Chart icon EZ Gauge Chart — Dashboard-style configurable gauge chart with red-zone indicator, adjustable range/arc, scale ticks, title and live value updates. Try it →
Unknown Country
Can not build robot
Can Not Build Robot
Hello,
I am trying to start building a robot, but the instruction view says "Completed" in the top left corner, and I am unable to proceed. I have not set up anything yet and am just exploring the platform. What can I do to resolve this issue? Has anyone else experienced the same problem?
Thank you!
Tutorial by mikebmac
Tutorial slide plugin for ARC: create, format and embed text and images per .ezb project; navigate/update slides via ControlCommand; auto-resize images
EZ-B Settings by EZ-Robot
Configures and pushes WiFi SSID, password, system name and channel to EZ-Robot EZ-B v4 from ARC; saves settings with project for quick redeploy.
Debug by Synthiam
Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear.
what robot are you using ? any pictures or short video is very helpfull .
Unknown Country
It is actually prebuild from my professor and now I use it on my computer. But if the robot is connected or not does not change anything. So I think it should be no problem. The library is also up to date
what happens when you close the instruction page and reopen it ?
Unknown Country
It stays like that. Did that multiple times, created a new project restarted my computer. Maybe reinstalling but dont know if that changes anything
you can try to remove ARC complete from your pc . delete browser hystory and redownload ARC .
Unknown Country
This sadly did not work. Still says the same
Unknown Country
Did it again. Now it works. Thanks for your help!
what excacly did you do again?
