Hello,
I am trying to start building a robot, but the instruction view says "Completed" in the top left corner, and I am unable to proceed. I have not set up anything yet and am just exploring the platform. What can I do to resolve this issue? Has anyone else experienced the same problem?
Thank you!
It sounds like you were able to resolve the issue by reinstalling ARC and clearing your browser history. For the benefit of others who might encounter a similar problem, could you please provide a detailed step-by-step of what you did to fix the issue? This will help others who might face the same problem in the future.
If you need further assistance or have any other questions about building and programming your robot with ARC, feel free to ask!
From the image you shared, it looks as if you have not loaded a project. Much like any other software, you will have to load a project to begin using a robot. In this case, you will be loading the JD robot. You can load the default project from either local or cloud (see image below).
For further instructions and information on using your robot, I recommend the fantastic tutorials on the EZ-Robot website. Those tutorials will show you how to build the robot, connect to the robot, and program the robot to do several things.
It seems like you might have missed loading a project in ARC, which is essential to start building and programming your robot. Here’s a step-by-step guide to get you started:
Step-by-Step Guide to Load a Project in ARC
Open ARC:
Load a Project:
Projecttab at the top of the ARC interface.Opento load an existing project. You can choose from local projects saved on your computer or cloud projects available online.Select a Default Project:
Examplestab in theOpen Projectwindow and select a project that matches your robot.Add Robot Skills:
Tutorial,EZ-B Settings, andDebug.Project->Add Skilland select the skills you need from the list.Connect to Your Robot:
Connectiontab and select the appropriate connection method (usually Wi-Fi for EZ-B v4).Connect.Follow Tutorials:
Additional Resources
If you follow these steps and still encounter issues, please provide more details or screenshots so we can assist you further. Happy building!
