I had to mount camera on it's side, rotate 90 degrees works fine on desktop but not when I use mobile app. am I missing something? confused
malc
On Variable Changed
— Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions.
malc
Hi @malc, did any of those suggestions from bot resolve the issue? Or are you still stuck?
unresolved so I use tablet on it's side and rember button's are sideways. malc
Hi @Malc! So I was testing this out, and then happened to hit the trusty question mark beside the camera image dropdown and saw that the mobile support for the flip/rotate setting is just for RotatenoneFlipnone, Flip y, and Flip XY! What did I learn? Always check the question marks!
...so to answer your question, no you are not missing anything, 90 degrees rotate is not supported for mobile.
cheers now I know. malc tired
