Sabertooth Movement Panel icon Sabertooth Movement Panel — Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options. Try it →
Resolved Resolved by Redzone!
Camera Not Working In Client Mode
Attempting to get this kit up and running. I've got the base running in client mode at last, and the camera is plugged in. Both are solid green status, and ARC is connected. When I try to add the camera control, it shows the same IP as the EZB device under "Video Device". When I hit "Start", I get a continuous stream of the following two errors:
ezbv4 camera image render error: System.ArgumentException: Parameter is not valid. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.E0xvOtux46(Byte[] ) at EZ_B.EZBv4Video.FGGTJPKZna(Int32 , Object ) ezbv4 camera image render error: System.Runtime.InteropServices.ExternalException (0x80004005): A generic error occurred in GDI+. at System.Drawing.Bitmap..ctor(Stream stream) at EZ_B.Camera.E0xvOtux46(Byte[] ) at EZ_B.EZBv4Video.FGGTJPKZna(Int32 , Object )
Can't seem to get it to work at all. Any ideas?
Make sure the port number for you camera is is 24 Example 192.168.1.1:24
In client mode your IP address must be detected by the camera control. There's a scan button just like the connection control. It's the same ip.
That's what it needed: the port number. Thanks!
