EDU Activity Editor icon EDU Activity Editor — Design, edit and export structured Blockly-based lessons, groups and hints for ARC Lite Portable; supports rich HTML, images, JSON import/export. Try it →
Boogie Question
I got my camera today ( the little blue one just like DJ's) and installed with the software that came with. When I select USB video device I get the. Built-in web cam. Will I have to disable the integrated web cam? Sorry bout that.............. I meat " noobie" question! I just hate ". Autocorrect!!!!!! The salutation for this post was meant to say: A noobie question!
Hahaha, I like boogie question.
You have a drop down with all of your cameras. well, you should. If you plug the camera in after you load the control then you will need to press the REFRESH button. Otherwise, all of your cameras will load into the drop down. Select which camera you'd like to use.
