Ohmnilabs Standalone icon Ohmnilabs Standalone — Connects Ohmnilabs Telepresence robot's UP Board COM to ARC, enabling drive and servo control (neck V0) and integration with ARC cameras. Try it →
Gibraltar
Bluetooth Antenna
hi all
is the BT antenna in this store differant to ones i can buy on the street coz i've bought a few now and still can't get connected i've reformated, re pared, replaced chip (thanks DJ) got new rechargable batteries still no luck. i've had my ezb since may and tried all i know except ez robots bt antenna ps i follow the communtiy avidly you're such helpful people and DJ is so dedicated:)
Hi bborastero are you still having a problem since may gosh. Remind me are you using a MAC with a windows emulator?
Gibraltar
no mate windows xp home ed and windows bt stack tired
Upgraded Firmware?
Or can't you get that far?
Gibraltar
no i can't get to upgrade it give this msg
Attempting connection to COM3 Comm Err: The operation has timed out. BbytesToExpect: 1
Received: Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.Connect(String portName) Disconnected
  1. Does the board LED light slowly blink?
  2. You can add the EZ-B as a Bluetooth device and enter a pairing code?
Gibraltar
1)board LED is blinking twice per second BT LED blinks faster but when i click connect it goes solid for 3 seconds ish then carrys on blining 2) yes paired as linvor with code 1234
Well its obviously trying do you have any other Bluetooth devices connected or something that maybe has a clash on your com port 3
Probably worth also going through the connection tutorial
Gibraltar
no i removed phone and re-paired ezb nothing else is in bt
