Movement Script icon Movement Script — Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ). Try it →
Bing Speech Recognition Not Starting Auto Recording
Hello there, After the last update of the Bing Speech Recognition, I noticed that it takes some time for the plugin to actually start Auto Recording after E-Z Builder is initialized.
Has this been happening to anyone else? It used to work fine before the update. It dows show "Auto recording at energy volume: -the level it detects above the threshhold-" (as seen on the screenshot attached), but then it does nothing. After some time, it starts the sequence of "Silence count" if it detects any sound.
This seems to happen only right after you initialize E-Z Builder.
Thanks, Gilvan
Yes I had this happen a couple times and noticed that the API keys didn't stay with the project file. I think DJ changed that, so that if you saved the project the key would not save if you shared the project, something like that.
