Hello I began to test the plugin Very catastrophic results in french Is there an option for language
Thanks for help
Auto Position Movement Panel (Gait)
— Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control
Thanks for help
Does not support French at this time.
The latest version supports a number of languages, including french.
thanks for all DJ , I will test to day I'm just also investigating in Cortana Speech Regognition . I have tested the Dictation Mode in an UWP application and the recognition rate is not so bad But it is only available IN UWP applications So I'm testing an UWP application as vocal recognition Server connected to an EZB plugin in TCP Mode I will share if it is successful
It's the same backend service from Microsoft - why not use the bing plugin as per topic of this discussion? It's a complete integration, not requiring tcp connections and uwp secondary application.
it is completely free not just some months try I think it is a good argument
I have tested the bing plugin in french. The recognition is very very good better than Cortana API I will use I think the service
Bing is free as well for 5,000 requests a month. That's 161 requests per day...
It's great
Yes it's great but I will continue my test
