EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
Auto Talk Board
Hi all just wondering if anybody has used an auto talk board with the starter kit ?,
If so your comments please on the auto talk board and if I was to use one, where on the starter kit board would I plug in the auto talk .
Many Thanks for any replies and help ?.
Regards
From what I read on the auto talk board it uses a jack input to control a servo. Which basically means, you would need to connect whatever you are using for your robot's voice (PC sound card, mp3 board etc.) to the auto talk board. The servo for the mouth then connects to the auto talk board also.
At no point does the auto talk board connect to the EZ-B, nor are any controls for it added in ARC. It is a stand alone board.
