Python Native icon Python Native — Run real CPython in ARC with full package support, camera access, ARC APIs, and bidirectional robot control. Try it →
Resolved Resolved by Athena!
Adventure Bot Improvement
so the adventure bot is for playing,i notest the batt wire is dragging on, the floor withs is not good.here simpel solution.put the wire on top. and like cars have a wing,adventure has one to now.
as you can see no wire below,comes out ontop.
DirectInput joystick control for ARC: drive movement panels, control servos, assign button scripts, variable speed and rumble feedback.
Good tip! I was thinking the same thing about him always dragging the charging cord. May have to see if I can convince my Builder to spare a cube he is currently using for Six's "hair" lol
alan can this pic of use for you?
Patrick, that is how mine is set up, and matches the assembly instructions in the sample project, but is different from Jeremie's picture, and about half the pictures in the store (but not the other half).
this jeremie pic.maybe he can post the front to.
Thanks for the closeups Patrick. that answered my question of why I couldn't make it work.
(with the front cube upside down, it doesn't fit right....).
It makes a good place to build a compass mount?
#16
Actually, with the front cube upside down, it was an excellent place. Will need to rethink it if I change to this configuration. Although maybe in this configuration I can put the compass on the bottom so the bright white LED on it is not so irritating....
Looking forward to getting home from work today so I can play around with this.
