Display Popup icon Display Popup — Full-screen popup display for ARC: show custom text with configurable timeout, font, text/background color, size and position via controlCommand(). Try it →
You'll need something that puts out at least 10amps (servos need a lot of juice)... A variable one so you can choose your voltage... 7.2V or so would work well... Still, to be honest rechargeable batteries are still the better way to go...
I agree the recharges are great, but when working on the bench i like to keep going and not stop and recharge ever so often.. I do the same with my Robotis, and other bots.. just want be able to do the same with a hexapod I'm building.. I only use rechargeable off the bench.. but if 7.2v will work I have a few of those laying round that might suit situation I just didn't want to blow the EZ-b4.
The servos are good with 7.4V and the ezb can handle up 17v or so,...so I think you're good...
You're welcome.... :) Just don't put 17V through your ezb4 and expect your servos to like it....:P
what if i put 10V or 11V is it ok with the servos ?
@Ahmed.Aranda 10V is too much for these hobby servos... They won't last long at that voltage...
i modified a power supply with 5k ohm pot and i got 8.15V, is this ok ?
