Brushless Motor Movement Panel icon Brushless Motor Movement Panel — Control brushless motor controllers (hoverboard-style) via EZ-B: configure direction, speed and optional brake ports for DIY robot movement. Try it →
ARC Crashes
Hi, I'm using ARC to control 2 EZB v3s and have a continued issue with crashes. I do have the latest version of ARC and the firmware on both boards is up to date but each time I try to open my saved project I get the error message as seen in the attached photo. I've rebuilt the project several time and get the error most times I open my project. If I open the project multiple times it will eventually fully load and work but its a bit annoying.
Any ideas what may be going on?
Gwen
Thank you for informing me about the error - it is fixed for tonight's release of ARC. The mp3 trigger will work with all EZ-B board indexes (not limited to #0)
Awesome DJ! Thanks so much!
