Myo Gesture Armband icon Myo Gesture Armband — Map Myo armband gestures and accelerometer to servos and ARC scripts for arm-mimic control; supports multiple armbands. Try it →
12V Or 24V Motor Controls
Hello Everyone.
Does anyone have the EZ robot controler operating 12v or 24v DC Motors ?
And if so can you give me some ideals for what type of motor controlers I can use that will interface with the device?
I will keep looking in the forums but any help would be greatly appreciated.
Thanks,
Woody
For motors of any voltage, you will need an H-Bridge. You need to determine the amperage of the motors, and then we can assist with recommendations.
Sabertooth has a wide variety of high amp H-bridges with a wide range of input voltage. Parrelax (sp) also has a good 25 amp H-bridge that a few people use.
Google "robo claw". I will be purchasing one of these units this week. The 2x30 version(2). I have 24 vdc wheelchair motors but will be running them at 12vdc. I was very impressed with all of its specs.
                                                      Chris
Thanks for all the input:)
I am using them to drive wheelchair Motors. So the amperage will be fairly high.
I still need to get a picture of the label sent to me to see the exact amperage.
Looks like I need to do some more research but you guys have given me some great starting points.
Thanks again.
Also does anyone have any suggestions on Blue Tooth Remotes ?
Take care,
Woody
Most people I have spoken to with wheelchair motors use the Sabertooth 2x25. I will also be using wheelchair motors on my large robot, and that is the H-Bridge I chose.
