ESP32_MPU6050 icon ESP32_MPU6050 — ESP32/Arduino EZB firmware with MPU6050 support: provides accelerometer angles and Yaw/Pitch/Roll gimbal servo values for stabilization and scripting Try it →
Ezb Mp3 Trigger Misc. Control Not Working.
Hello,
When i test my mp3 trigger with the ezb software:
only control i have on the screen is the mp3 trigger board
it works fine....
but when i open my saved file with all my controls and sensors and everything....
the mp3 trigger board doesnt work anymore....i can manually play tracks froim the mp3 trigger it self but if i try to assign commands within the ezb software or even try to play a track through there....nothing...
Check to see if any of the controls in your project are configured to use the same port as the mp3 trigger
yeah, ive looked and nothing else is using port d0
no servos no scripts
i did notice i have to "double click" on a specific number on the mp3 trigger board to make it work...
if i single click on a specific number the head will slightly move, but no sound.
if i double click that number the head does not move and i do get a sound.
also, no script will play an mp3 trigger command... for instance i replicate your "whats your name" command...
i have to ask 10 times before he replys....
not sure but nothing else is using port d0 and again from the physical mp3 trigger i can scroll through all of the mp3 no problem...
and again, if its the only widget on the screen, it works fine.
yeah im not sure what the problem is but after the update mp3 trigger control still no worky
also, relative servo position has been lost....
example....now only one servo for the eyes , and tilt feature is working....
scripts were running fine before but now its like wall-e had a stroke.
btw, i did notice the movement is much much smoother, thanks for the hard work.
Is anyone else having an issue with this? Is it just me? Anyone....
ok it was port d0....this port is no good for the mp3 trigger, i switched it to port d1 and it is all good now....
again D0 i think from what ive read, has a higher signal than other ports.
so any other port will do for the MP3 trigger
hoolagen: thanks man hoolagen: no problem hoolagen: love this forum
