Speech Script icon Speech Script — Run custom scripts when speech starts/ends to sync servos and LEDs to spoken $SpeechTxt, with loop support, stop button and logs. Try it →
Reunion
Firmware Upgrade Reboot And Slow Blink
Hi I just turned on my EZB and I have to upgrade my firmware.
I connected to the firmware updater Started the bootloader upload It says "firmware loaded. reboot EZ-B" So I pull out the battery and put it back in Now the board started but the large LED is pulsing slowly with a fade effect.
What's going on? Did the firmware update succeed? Is it still updating? Is it ready? stress
If you run the updater again and it said you have the latest firmware, then it is already updated. What you do is close ARC and reopen it, reconnect bluetooth in ARC and it should go solid again. Hope that helps.
Best regards, Louis
Reunion
Ok so the slow blink is a new feature of this firmware.
I don't know if its new but after i updated mine it does the same thing.
Reunion
Thanks for your help.
