Camera Device icon Camera Device — Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts Try it →
You probably can get away with it. However, you might draw so much current that you won't be able to run any servos at the same time. Worst case scenario is you blow a fuse, really.
Is the Dlink IP cam compatible with ARC? Or are you not using it
Hello DJ
If I run a 7.2V 5000mah battery to the EZ-B will I be able to power the IP cam from the ez-b 5V output?
Thanks!
You'll have to consult Mr Ohm for peripherals in addition to the camera
Worst thing that will happen is a blown fuse:)
Hello DJ
What is the max current output of the ez-b 5v regulator? I recall it saying 3.5A?
Thanks!
